Hi all,
I'm currently designing a circuit including the small ORG1411-PM04 module, which runs on 3.3V (the PM01 runs on 1.8V).
I would like to avoid an external 1.8V LDO, but now ask myself if the I2C SCL and SDA lines will work (IO output level of the ORG1411 is 1.8V). They are pulled up by 4.7k to 3.3V (near my ESP32 MCU).
The ORG1411 datasheet says:"SCL and SDA are pseudo open-drain lines, therefore require external pull-up resistors of 2.2kΩ to 1.8V, or 3.3kΩ to 3.3V.".
Means it should work, right? Even if SCL and SDA are on 1.8V level on ORG1411 side and 3.3V on MCU side? I'm not a big I2C expert.
I attached the schematic (without the 4.7k pull-ups for I2C, they are located near the ESP32 MCU).
Thanks in advance,
Timm
