Wait, you have three mosfets driven from one opamp? If so, I suggest drive them individually. If you drive fets independently, does it oscillate when you use only one channel?
As of stability, try
1) increasing the cap
2) lower R3
3) add resistor from opamp output to ground (100-2k, experiment here).
