Author Topic: First PCB  (Read 12545 times)
Offline jackjrTopic starter
First PCB
« on: August 22, 2012, 07:42:51 am »
First post here, and first PCB!
It's basically a breakout board for the SIM900 GSM module.
Since I'm a total beginner, I would like some feedbacks before I send it out for manufacture.
The schematics and PCB are attached below.
I've also a couple of questions:
a) For the RF antenna output, the SIM900 hardware design guide recommends using 50ohms impedance controlled traces, and an antenna matching circuit. This seems to add quite a bit of complexity, so… Is this really needed?
In my circuit I just connected directly the RF_ANT output of the SIM900 to the SMA connector, using a short (~8mm length) 25mil trace. Will it work?
b) Is the grounding good enough?
c) Tenting or not tenting the vias? In my design most are tented.
Thanks for reading  ;)
Offline PSR B1257
Re: First PCB
« Reply #1 on: August 22, 2012, 08:15:48 am »
Therefor, you could simply adding a 47R resistor instead of a controlled impedance trace.
Yes, it looks pretty good. Especially the amount of vias.
But you should change your VBAT-trace. Because there is an acute angle (close to the yellow square) which should be avoided in any layout on any trace.
In theory, there is no difference between theory and practice. But, in practice, there is.
Offline poorchava
  • Troll Cave Electronics!
Re: First PCB
« Reply #2 on: August 22, 2012, 08:47:46 am »
I would consider pouring GND on both layers and then stitching them genrously with a lot of vias.
Offline PSR B1257
Re: First PCB
« Reply #3 on: August 22, 2012, 09:01:45 am »
I'm not familiar with Altium (by the looks of it), but I thought there is a GND-plane on the opposite layer, which is just not shown  :-\
Why should he have that plenty vias on the GND-plane else for...
BTW: On Eagle, you got the same problem. There you have to click on Rastnest, to make the GND (or whatever net it is connected trough) polygon visible.
Offline mtkaalund
Re: First PCB
« Reply #4 on: August 22, 2012, 09:21:13 am »
Does this not mean there is missing a connection?
if it does then there a quite a lot missing
maybe but I would not count on it, you'll going to need to know the "high" of the copper layer on the PCB in order to calculate it properly. Take a look at http://smartdata.usbid.com/datasheets/usbid/2001/2001-q1/slua236.pdf
"Keep buggering on" -- Winston Churchill
VIR => V = I*R, neat ;)
Offline PSR B1257
Re: First PCB
« Reply #5 on: August 22, 2012, 09:39:35 am »
Well, that's the question  ;)
If you take a usual 35µm (which is equal to 1oz) you get about 6.2m? - that's literally nothing.
Offline Short Circuit
    • White Bream electronics R&D
Re: First PCB
« Reply #6 on: August 22, 2012, 09:47:22 am »
Impedance matched traces on a double sided board are almost imposible, if I recall correctly you'd need traces about 3mm wide. Obviously that does not go well with the GSM module, nor with the connector... For a short link like this one, just use a trace as thick as possible, and you'll be fine.
An antenna matching circuit is only needed when the antenna is not a standard 50 ohms model, such as PCB antennas.
Re: First PCB
« Reply #7 on: August 22, 2012, 09:47:55 am »
The missing connections are connected to the GND pours.
And yes there is a GND pour on each side.
I tried to setup a rule in Altium to control the impedance of the trace to 50ohm, which would then automatically adjust the size of the trace, but that did nothing.
« Last Edit: August 22, 2012, 09:49:28 am by jackjr »
Offline Thor-Arne
  • Country: no
  • tinker - tinker, little noob.....
Re: First PCB
« Reply #8 on: August 22, 2012, 10:19:06 pm »
I suspect it shows as unconnected nets because the GND pour is not there on that capture.
The second image don't have those, so I suppose it's ok.
Thor-Arne
Offline mtkaalund
Re: First PCB
« Reply #9 on: August 23, 2012, 07:58:54 am »
Thor-Arne
Yeah for the GND pour, but there is still one connection missing
You are right, this can be overlooked/ignored in this design.
Offline AndyC_772
Re: First PCB
« Reply #10 on: August 23, 2012, 08:09:08 am »
I don't see a SIM chip anywhere. Would it not be useful to include the SIM connector on this board too?
Offline Thor-Arne
  • Country: no
Re: First PCB
« Reply #11 on: August 23, 2012, 08:42:39 am »
You are right, there's a unconnected net on R4 also.
@jackjr:
I'm not familiar with Altium (if that's what you're using), but there should be a function to check your design for errors.
« Last Edit: August 23, 2012, 08:53:20 am by Thor-Arne »
Re: First PCB
« Reply #12 on: August 23, 2012, 12:16:41 pm »
Thanks for the replies.
I didn't see the missing connections. I fixed them.
@AncyC: we can't see it very well, but there is a SIM card connector on the bottom layer.
Offline papo
Re: First PCB
« Reply #13 on: August 23, 2012, 08:44:53 pm »
Hello
You may want to check the distance of your mounting holes to the PCB edge. On my first PCB, I put these holes too close to the corners of the PCB and the corners just broke off because there was not enough material between the edge and the hole.
Regards
Matt
Offline atbreaux
Re: First PCB
« Reply #14 on: September 18, 2012, 07:48:51 pm »
Thor-Arne
i would be careful to ignore these.. because sometimes your pour will not be be connected to the ground leaving a big island pour between traces making the pin connected to that island effectivly not grounded.. i normally just use the odb++ drc for unconnected nets when something like this arises just to be safe.
Offline free_electron
    • SiliconValleyGarage
Re: First PCB
« Reply #15 on: September 18, 2012, 08:29:31 pm »
If altium shows you an error or warning it is an error or warning and you NEED to fix it.
when pouring polygons always check the option to remove unconnected copper. you will immediately see what is wrong then.
Offline Electronic_Project
  • Electronic Project Android Smart Control
    • Smart Android Control Electronic Project Module
Re: First PCB
« Reply #16 on: November 23, 2012, 03:13:36 pm »
I think your design is OK,
But I prefer to connect the antenna with a straight short track to module
and connect the adjacent GND pins of this pin directly to antenna connector GND pins.
In addition if you are going to order this PCB without the overlay layer,
keep copper out of area marked with a solid fill rectangle.
Offline chklopper
Re: First PCB
« Reply #17 on: June 25, 2013, 09:25:57 am »
 :scared: Hi
i just wanted to know did the break out board work as planned as there is no mention of it acctually working ok.
Regards Carel
