Author Topic: Sciensta soldering kit  (Read 549 times)
Offline AlloabearTopic starter
« on: January 17, 2025, 08:58:12 pm »
https://amzn.eu/d/hfkuVMU
Hi all, absolute beginner here. So ive began soldering very recently and started doing those starter kits basically for kids.
But this one hasn't turned out as well as I'd have liked. It turns on but the two led screens aren't working as they should. For a start they have different brightnesses and more lights are on than there should be. So there is no discernable distinction in numbers etc.
I've checked all my joints for continuity, changed the triode and checked to see if I'd missed any joints for soldering.
Would anyone have any ideas what noob mistake I've made here or is it possible that the screens/chip are faulty?
Thanks for any advice, I know it's not a massive problem but it's frustrating none the less
Offline ataradov
    • Personal site
Re: Sciensta soldering kit
« Reply #1 on: January 17, 2025, 10:11:59 pm »
Can you show some pictures?
This is just a really shitty kit. They are relying on the I/O pins for the current limiting for the LEDs. This is really bad and can lead to all sorts of issues.
If it is doing anything at all, there is a good chance it is working as expected, it is just not expected to work well.
« Last Edit: January 17, 2025, 10:14:13 pm by ataradov »
Alex
« Reply #2 on: January 18, 2025, 12:35:05 pm »
Thanks for the reply. Here is a couple of photos. Pick apart my soldering at will haha
https://postimg.cc/HV2PqSWW
https://postimg.cc/gL6LvtMV
Offline ataradov
    • Personal site
« Reply #3 on: January 18, 2025, 03:29:22 pm »
I would double and triple check that you have them in a correct orientation. It is hard to tell if it is correct from thew blurry dark picture.
Those displays have alignment indents and protrusions. If I'm not mistaken you should have indents on the bottom of the board. Pin 1 is next to an indent.
« Last Edit: January 18, 2025, 03:34:29 pm by ataradov »
Alex
Offline Shock
« Reply #4 on: January 18, 2025, 03:30:13 pm »
Please don't post shortened URLs to forums learn how to post a URL and delete all the affiliate and tracking crap.
Offline ahsrabrifat
  • Country: pk
« Reply #5 on: January 30, 2025, 09:27:08 am »
Since you have checked all of the joints and found no mistake, I think it's a faulty hardware.
