Author Topic: Why is the RSC resistor needed to sample the choke current in the system?  (Read 1327 times)
Offline akeaTopic starter
Hello guys. Can u pls tell me Why is the Rsc resistor needed to sample the choke current in the system? Thank you
« Last Edit: May 05, 2019, 03:24:13 pm by akea »
Online T3sl4co1l
    • Seven Transistor Labs
The system?
Seven Transistor Labs, LLC
in converter
« Last Edit: May 05, 2019, 01:29:04 pm by akea »
Offline soldar
Anyone knows Why?
Offline mikerj
No one has any idea what you are talking about, you haven't even described the system you are referring to.
sorry about it. i have just uploaded the system
Offline mikerj
The circuit seem to be incomplete, there is no inductor (choke) shown.
The device block diagram looks like an MC34063 switching regulator, is that correct?  If so the resistor is used to provide current limiting, if the voltage drop across the resistor is greater than 300mV the duty cycle will be reduced to lower output voltage and hence lower the current.  Without current limiting an accidental short on the output could destroy either the regulator or the load.
Yes its correct.Thank you very much  :)
