Hello!
I'm currently adding leds to my subwoofer, and ran into a little problem.
The problem being, I need to turn up the bass a lot to make leds glow.
So can anyone give me any tips and advice on how should I approach this, my electricity skills aren't great but I can do the basic stuff such as soldering, and I'll explain what I actually need to do down below.
Input is 12v (or higher, haven't measured it (from the amplifier)), I need to keep the output1 (woofer) at the input voltage and boost output2 (leds) to make them glow even on low volume and aswell put a 12v voltage regulator between the boosted voltage and the leds.
What I'm working with:
LEDs are 12v (led strip)
Subwoofer is Logitech Z906
Makeshift diagram of how it should look like (I think):
