Author Topic: Oscilloscope for lcd TV troubleshooting?  (Read 1067 times)
Offline wadmancpuTopic starter
« on: August 29, 2018, 04:32:29 pm »
I was wondering what everyones opinion is on having an oscilloscope for doing tv repairs and troubleshooting. A good investment or unnecessary?
Offline keymaster
  • Country: gr
Re: Oscilloscope for lcd TV troubleshooting?
« Reply #1 on: August 29, 2018, 06:52:50 pm »
In most cases ,it will be useless .
50% will be the leds
10% will be the diodes or feds of the power supply
15% will be capacitors ( it was much higher a few years back)
5% will be software problems and firmware corruption
5% will be connectors and ports damage
And the rest 15% will be problems in the digital boards (the only place you will need an oscilloscope ) but most of the time will be to difficult or no cost effective to bother.
a multimeter and a soldering iron is all you need.
tools that will make your life easer is a led tester or a lab power supply to test the led streps individually . i use a variac with a full bridge rectifier and a 1kohm in series to test all the leds before i start the disassembly of the panel
The following users thanked this post: wilfred
