Thanks for all the tips, warnings and information!
I still feel like my question wasn't answered though...
Assuming I never actually connect my scope probe(s) to an AC mains earth referenced DUT without proper safety equipment (isolation transformer, differential probe), I would
still like to know the answer to my questions for the purpose of technical understanding.
Scenario #1:With the DUT powered off and any component able to store energy discharged...
I use my DMM to test resistance between test point A and the earth pin on the DUT's power cable to verify that test point A
is indeed a direct connection to mains earth. With the DUT still powered off, I connect my scope probe's ground lead to test point A.
I connect the scope probe to some other point in the circuit and then plug the DUT's power cable directly into a wall outlet.
Assuming mistakes were not made during the setup of Scenario #1 (I understand this is the point of the safety gear as mistakes do happen).
We're also assuming that we power down and discharge the DUT if/when we move the scope probe to different test points, while maintaining
test point A as our ground lead location.
Scenario #1 Questions:- Is this "safe"?
- Are all probe points "safe"? (Assuming we're not moving the ground lead)
- If some probe points are not "safe", what would those be and why?
I think the answer to these questions are that this is OK. I couldn't think of any reasons why it wouldn't and that's why I'm asking.
Not to take short-cuts with safety gear, but because I want to solidify my understanding.
FYI - I've purchased a bench isolation transformer from Jameco since first posting this question.
