Johnson, Graham
"High - Speed Digital Design. A Handbook of Black Magic."
thank you all for the reply
I am aware that a probe loop catch electromagnetic through the air
But this time I was amazed by the fact that a new strong noise appears only when i electrically connected the loop to the circuit.
Users suggested me to pay attention to the "common mode noise" topic.
But i fail to realize how relevant it can be in my case, how to test it. I don't even know if it is possible to check if a power supply is a source of "common mode noise". Does it make sense to speak in these terms?
I also can't imagine a situation where two connected to earth equipment can be joined together without generating common mode currents.
I made a schema to visualize my perplexity.
Let's say that device A transmits a certain current to device B through the SIGNAL cable.
The current will flow back baybe through GND or EARTH, you cant tell.
So if not all the current return to A through GND the consequence is that some common mode current appear on the SIGNAL/GND pair.
Is my reasoning correct?
So I see tree options:
-Common mode current is normal behavior
-Two or more connected to earth devices cant be joined
-I dont get the point
For example an Arduino board connected to PC USB hub (PE connected) AND an Oscilloscope (PE connected) can be be joined (I mean connecting their GND together) ??
In this case the current coming form PC USB will flow back to PC not on the usb cable but on the earth cable since its bigger and maybe low impedence. Then again a comon mode current appears on the usb cable.
