I have Rohde und Schwarz RTB2004 with vertical specification attached as per image.
When I turn scope on it is is reading about ~300mV on instrument's DVM when turned on. But it settles down to around 20mV on 2V/div range (Total 20V full scale on screen), after one a minute or two of operation.
All channel have similar behavior. All read few hundred millivolts initially and then slowly settles down under few millivolts.
This value of a constant offset seems to be variable depending on range vertical setting, it is in uV when scope is set to 1V/DIV or less and reading around 500mV when scope is set to 50V/div (500V full scale.
My question is, Is this normal, If yes Which specification of scope defines it. Is this what called "Zero error"?
In Attached image you can see screen shot of scope, all channels are at 0V offset but they are not perfectly over one another. Is this normal?
" alt="" class="bbc_img" />
