Author Topic: TL431 not giving expected voltage  (Read 5210 times)
Offline Dannyx
  • CertifiedAxhole
Re: TL431 not giving expected voltage
« Reply #25 on: May 23, 2024, 09:13:41 am »
It's a TI 431A part, so I assumed a 4.7uF cap would be adequate. I assume the current IKA in the graph is directly influenced by the value of the resistor I use from the supply to the 431 cathode ?
DannyX
Offline ledtester
« Reply #26 on: May 23, 2024, 09:54:34 am »
Yes.
Concerning the need for a cap, note that TI says:
The TL431, TL432 family of shunt regulators were designed to have wide bandwidth while ensuring stability without any external frequency compensation. This makes the device very useful in a control loop application and as a reference voltage generator without external capacitance.
and these comments in the electronics stackexchange...
( https://electronics.stackexchange.com/a/332065/954888 )
« Last Edit: May 23, 2024, 10:08:25 am by ledtester »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #27 on: May 23, 2024, 12:43:18 pm »
If you want to make something unconditionally stable across production and substitution, I would suggest reading all the datasheets you can find -- across diverse manufacturers, and different versions across time -- and find the inner (min guaranteed stable C) and outer (max guaranteed stable C) loci across all plots you can find.  Then add a factor of 2 or more for safety.
Or use the RC circuit; or both strategies, for that matter!
Related thread for reference: https://www.eevblog.com/forum/projects/tl431-with-resistor-divider-on-ref/
« Last Edit: May 23, 2024, 01:05:45 pm by T3sl4co1l »
Seven Transistor Labs, LLC
