Author Topic: BJT forward bias question_1  (Read 1115 times)
Offline khatusTopic starter
  • Country: gl
« on: April 19, 2022, 04:15:06 pm »
What does it mean by boundary here? does Boundary refer to the depletion layer?
Offline bob91343
Re: BJT forward bias question_1
« Reply #1 on: April 19, 2022, 04:19:46 pm »
I think yes.
Offline TimFox
« Reply #2 on: April 19, 2022, 04:24:40 pm »
The "boundary" is between the P-doped and N-doped regions.
The depletion layer forms on both sides of that boundary:  at zero bias, the depletion layer forms normally to a finite thickness.  Applying a reverse bias will increase the thickness of the depletion region.
One example of this is a diode (varicap or varactor or tuning diode) that is optimized for use as a variable capacitor:  the capacitance at zero bias is relatively large (thin depletion region) and increasing the reverse bias causes this capacitance to decrease.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: April 19, 2022, 04:51:35 pm »
the depletion layer forms BETWEEN the boundaries.
Offline TimFox
« Reply #4 on: April 19, 2022, 05:21:47 pm »
No, there is a boundary between N and P regions, and the depletion region forms on both sides of the boundary.
As a non-electrical analogy, consider the "frontier" between two nations at war, with a "no-man's zone" on both sides thereof.
« Last Edit: April 19, 2022, 05:26:01 pm by TimFox »
Offline mawyatt
« Reply #5 on: April 19, 2022, 06:05:29 pm »
The BETWEEN the boundaries isn't correct!! As TimFox mentioned, under no bias the depletion region or layer extends beyond or OUTSIDE the boundary or semiconductor interface where the mobile charges are depleted. Under reverse bias conditions this depletion region extends further and can be "viewed" as somewhat like parallel plates of a capacitor with separation (depletion region) under voltage control. Under forward bias conditions the depletion region collapses and you have available mobile carriers and current flow.
A simple thought experiment will show that if you have a pair of doped semiconductors, one is P type the other is N type. When you bring these separate doped semiconductor "faces" into contact, the boundary is obviously the physical interface between the two semiconductors, however the depletion region extends into both semiconductors from the boundary interface in both directions. You can calculate the depletion region width based upon Poisson's and Gauss's Law, see below.
From Wiki:
https://en.wikipedia.org/wiki/Depletion_region
Anyway, hopefully, this will make things a little clearer for the OP which is everyone's intent :-+
Best,
Edit: Semiconductor physics can be daunting at first, but if you can make analogies and think in terms of more common things then it becomes much clearer. For instance, even the very complex Silicon Germanium bipolar transistors with the base emitter band-gap engineering can be understood as having an electric field of such magnitude that the carriers are quickly swept across the junction by the high fields, thus improved speed. These junctions can even be tailored to produce super-beta bipolar devices, or even possible devices where no base bias is required for significant collector emitter current flow (although don't recall anyone ever trying this).
Another example is when IBM used Germamium in CMOS to tweak the lattice structure by means of induced strain due to the lattice mismatch between Silicon and Germanium. This was what we used to call Ballistic CMOS where the free carriers flew down the channel like a bullet in a barrel with much fewer collisions, or in semiconductor terms the carrier mean free path became larger.
« Last Edit: April 19, 2022, 07:15:13 pm by mawyatt »
~Wyatt Labs by Mike~
Offline rfeecs
« Reply #6 on: April 20, 2022, 04:55:43 pm »
The text is poorly written or just makes no sense.  Electrons don't recombine with the ions.  Electrons recombine with holes.
It's a common simplifying assumption that there is very little recombination in the depletion region because the hole and electron concentration is very low.
So by "boundary", the text must mean the edges of the depletion region, not the boundary between the n and p region.
Find another text book.
Offline TimFox
« Reply #7 on: April 20, 2022, 05:27:13 pm »
Not to disagree about the text being poorly written, but the "edges" of the depletion region are not fixed, since they vary with bias voltage, and they would be two "boundaries" (plural).
Offline rfeecs
« Reply #8 on: April 20, 2022, 05:35:39 pm »
Yes.  So poorly written or just makes no sense.
Offline mawyatt
« Reply #9 on: April 20, 2022, 06:01:19 pm »
Agree the text is poorly written, but does convey that the depletion region is not a fixed "boundary" per discussion. The Depletion Region is also highly temperature dependent, as well as highly dependent on doping profiles and density.
Best,
Offline rfeecs
« Reply #10 on: April 21, 2022, 04:15:55 pm »
It would have been better to just say
The application of a forward-bias potential will reduce the width of the depletion region.
The rest of the sentence, about recombination and "the boundary" is just plain wrong.
Offline tooki
« Reply #11 on: April 21, 2022, 07:05:05 pm »
The title of the thread mentions BJT bias. The book snippet is talking about DC bias applied to a diode’s PN junction. Do you actually have any question about BJT biasing?
P.S. for those wondering, the snippet from Electronic Devices and Circuit Theory, 11th ed by Boylestad and Nashelsky.
Offline emece67
« Reply #12 on: April 22, 2022, 02:28:57 pm »
« Last Edit: August 19, 2022, 05:24:09 pm by emece67 »
« Reply #13 on: April 22, 2022, 08:17:43 pm »
Maybe this is a translation issue but i understand "boundary" to be the area between either N or P material and the depletion area. So you have 2 boundaries: N to depletion and P to depletion.
