Author Topic: 5mm LEDs in chains - are they all manufactured this way or are these special?  (Read 806 times)
Offline badrequest400Topic starter
Does anyone know what these weird-lookin' LED chains are (see attachment)? Is this how all LEDs are manufactured and they just haven't had those bottom bits cut off or are these specially-manufactured to be like this?
Offline mariush
Resolution's a bit low, but you can see here similar leads :
The following users thanked this post: thm_w, badrequest400
Offline Benta
It's for automatic pick-and-place PCB assembly.
In 99% of the cases, the LEDs have cut leads and are taped to a self adhesive band at the end of the leads and then be wound on a roll (or an "ammo-pack").
The PaP machine will unwind the roll, cut each LED and insert it into the PCB.
In this case the manufacturer opted for a simpler solution with a special leadframe instead of the tape. Cheaper? No idea.
« Last Edit: April 22, 2022, 08:00:28 pm by Benta »
The following users thanked this post: badrequest400
Online langwadt
the leadframe maybe how they are produced, before being cut to be put in ammo-pack or bags
makes sense to not handle them individually when molding the plastic, and the series string might be used for a quick test
Offline thm_w
  • Non-expert
Same channel they are bonding the dies:
Good article here: https://learn.sparkfun.com/tutorials/how-leds-are-made/all
Offline eugene
Seems that handling the strips could be dangerous for the LEDs. If you were to roll the strip it would put torques on the leads. Leaded LEDs seem pretty rugged, but still.
90% of quoted statistics are fictional
Offline thm_w
  • Non-expert
Why would you roll the lead frame strip? Or are you talking about the paper ones.
Offline floobydust
Nothing goes to waste in china, they'll sell any rejects, blemishes etc.  A few 5mm LED's I've bought are marked backwards polarity and OP's looks like the leads are uncut.
It doesn't mean they are unusable for hobby stuff.
Offline xrunner
  • hp>Agilent>Keysight>???
My Gawd can you imagine doing that all day long every day?  :palm:
