I know OTP mode stands for One Time Programming, and the application note I'm reading reading says the AEAT-6600-T16 is a "One Time Programmable ASIC". My question is: does the "One Time" mean once only period, or can you once again connect the higher OTP voltage (it takes 6.5V) and reprogram the chip, just not during normal operation? I'd like to experiment with several different encoder resolutions and modes, and would like to know whether I'll need a bunch of chips for that. Thank you.
