Author Topic: Output pulse shape  (Read 423 times)
Offline elkiTopic starter
Output pulse shape
« on: April 18, 2024, 12:44:53 pm »
I am sorry but I have a very newbie question. I have some circuit from which I get the two types of outputs, depending on how I look at it with an oscilloscope. In the first case it is just directly connecting to the output through a very big resistor without any load. In the second case, I use 1k to ground. Obviously, the first case is problematic, because I am basically capacitively read the output without any load. However, this is the shape that I want. Could you please suggest a proper way of arranging the output stage to get the pulse shape as shown in the first case?
Offline jwet
Re: Output pulse shape
« Reply #1 on: April 18, 2024, 02:41:00 pm »
Can you put some numbers on these waveforms, especially time and maybe give other details.  I'll try to answer with what's given...
The first case looks like a high impedance source, something like a 10k output impedance.  Its not affected by 100k (likely 100k with 10 meg in series from the scope).  You should be able to just use a 10x scope probe- the 100k isn't doing much.  It might be isolating the direct cap load of the probe...
The second case is pretty confounding- it doesn't look possible.  The first pulse is what you might get with a capacitively coupled output, the width of the pulse is a few RC's but the second pulse is somewhat impossible from a linear circuit, it rises before the output rises then follows it down.  This is non causal and suggests some kind of triggered delay from the rising edge - not linear.  A classic under cap coupled output would have the the first edge create a pos pulse and the second create a neg pulse.
The following users thanked this post: elki
« Reply #2 on: April 19, 2024, 07:08:01 am »
Thank you. Here is an example of the problem I am dealing with.
I have a high impedance input signal on R1. I am trying to convert it to a low impedance output on R2. Obviously, if I further reduce the input current by increasing R3, my output voltage on R2 becomes zero. Naively, I thought that the proper way of dealing with it would be to have an op amp buffer placed in-between R1 and R2, but somehow it does not work. Does anyone have a suggestion? The input signal is about 10-20mV.
Offline Andree Henkel
« Reply #3 on: April 19, 2024, 01:04:51 pm »
What is Purpose of R2?
If you want to drive coaxial cable with 50Ohms WaveImpedance with signals of high enough frequenzy or short enough rise / fall times
and you want to correctly source terminate?
Then R2 needs to be in series to the output, not to ground
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #4 on: April 19, 2024, 01:49:10 pm »
It's impossible. No any passive network can convert high impedance input to low impedance without loosing signal power a much.
Exactly. And may be even without R1 & R2 ;)
