Author Topic: Over voltage protection and reverse polarity protection  (Read 1434 times)
Offline roogadgetTopic starter
« on: September 26, 2018, 05:17:10 am »
My specs are 9V - 15V.
My project requires Over voltage protection and reverse polarity protection.
What is the "best" way to do this for a simple project?
Do I design a circuit to check for this or do i just go with a chip that handles it??
Offline JPortici
Re: Over voltage protection and reverse polarity protection
« Reply #1 on: September 26, 2018, 09:21:22 am »
PTCC + TVS may be a very simple solution, need more information
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: September 26, 2018, 12:37:47 pm »
Nominal load 1mA or 1kA?
Overvoltage of 16V or 16kV?
Reverse of -1V or -1kV?
Is it a slow swell, fast transient, lightning surge, nuclear EMP?
Once you know the voltage, current and time scales of the system, methods become apparent. :)
Seven Transistor Labs, LLC
Offline Neilm
« Reply #3 on: September 27, 2018, 06:39:55 pm »
Is this a personal project, or does it have a commercial application? If the latter, does it have to meet any standards, for instance automotive standards?
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Brumby
« Reply #4 on: September 28, 2018, 02:24:28 am »
As above ... More information needed.
Offline 6PTsocket
« Reply #5 on: September 28, 2018, 11:07:28 am »
Not knowing your exact situation, a diode for reverse voltage protection and some simple 3 pin voltage regulator that handles a wide enough range of input voltage. As mentioned above, you need to be more specific for more specific suggestions.
Sent from my SM-G900V using Tapatalk
