Author Topic: Dimming signal 0-12V from microcontroller (logic level to 12V PWM)  (Read 2616 times)
Offline Zero999
  • 0999
Re: Dimming signal 0-12V from microcontroller (logic level to 12V PWM)
« Reply #25 on: May 05, 2024, 07:52:24 pm »
The magic smoke escaped from the MCP6H81 because 12.5V is greater than its rated maximum of 12V
(duh, but the router wall wart was the most convenient 12V supply I had kicking around),
so good thing I also ordered some TLV272s which are 16V tolerant.
Only when run off a 16V supply, otherwise the maximum rating of the inputs is 0.2V above the positive supply.
https://www.onsemi.com/pdf/datasheet/tlv271-d.pdf
