Author Topic: What is this part? (photo included)  (Read 516 times)
Offline Dan MoosTopic starter
« on: July 04, 2023, 10:37:38 pm »
Reads like 4 pF. I'm not convinced its a cap though. No other markings other than what are shown.
Offline Benta
Re: What is this part? (photo included)
« Reply #1 on: July 05, 2023, 12:53:03 am »
Ceramic cap in the pF range. Looks like an old Philips type.
1 pF could be right, but unusual.
Offline ArdWar
  • Country: sc
« Reply #2 on: July 05, 2023, 03:35:26 am »
I was wondering when the last time anyone see color-coded capacitor until I realize the color don't exactly make sense.
Maybe the base is supposed to be white/gold, which means it should be 2.7pF
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #3 on: July 05, 2023, 06:17:54 am »
Philips 2222 680 series ceramic cap 1pF, probably 100V rated.
This series of capacitors is intended for temperature compensation applications and the red/violet coding is for the temperature coefficient; in this case +100ppm/℃ (P100)
Other temperature coefficient colour codes:
   Black     NP0
   Red       -75ppm/℃ (N75)
   Orange  -150ppm/℃ (N150)
   Yellow    -220ppm/℃ (N220)
   Green    -330ppm/℃ (N330)
   Blue      -470ppm/℃ (N470)
   Violet    -750ppm/℃ (N750)
The extra 3pF you are measuring is probably stray capacitance. You need to zero out your meter or test fixture before measuring such small capacitors.
« Last Edit: July 05, 2023, 06:30:52 am by srb1954 »
