Okay thanks. So power + D S - S D load Gnd?
Quote from: Sounduser on April 07, 2015, 07:28:30 pmOkay thanks. So power + D S - S D load Gnd?YesHere's an example:From this page:http://www.electronic-products-design.com/geek-area/electronics/mosfets/using-mosfets-as-general-switchesWhen the control is high, current can flow in either direction through the switch. When the control is low, current can not flow in either direction.
but the turn off will be slow, will that make the fet overheat?you have to make sure this arrangement is protected from a shorted load, a lot of the power will be absorbed by the not fully turned on FETs, but I guess you would have had to protect against this anyway.
