Author Topic: cap dialectric  (Read 8776 times)
Offline p.larnerTopic starter
cap dialectric
« on: January 05, 2024, 08:24:05 pm »
i am thinking of making some fixed caps for an atu,it will be copper fr4 sandwitched with 0.36mm nomex sheet as seperators,the fr4 boards are 6 inchx4 inch,will that work for high voltage?https://www.ebay.co.uk/itm/144648265472
Offline TimFox
Re: cap dialectric
« Reply #1 on: January 05, 2024, 08:30:47 pm »
Why not use a well-characterized low-loss dielectric material such as polypropylene?
In any sandwich construction, be careful to avoid air gaps in the stack, where the adjacent dielectric will increase the E field (voltage gradient) in the air by it’s dielectric constant.
Re: cap dialectric
« Reply #2 on: January 05, 2024, 11:12:35 pm »
simple realy as i have a sheet of the stuff,i brought it to use the insulate the windings from the stator on an ebike hubmotor rewind,so ive a lot left over+its tough.
Offline TimFox
Re: cap dialectric
« Reply #3 on: January 06, 2024, 12:20:18 am »
Nomex is an electrical insulator commonly used for fire protection, but I don’t know it’s dielectric properties, constant and loss. It is often a fibrous construction.
Did you look up its properties to design the capacitor?
Polypropylene has excellent voltage capability, so thin sheets can be used.
Polyester (MylarTM) is mediocre for loss.
Re: cap dialectric
« Reply #4 on: January 06, 2024, 11:14:42 am »
i found this
Offline TimFox
Re: cap dialectric
« Reply #5 on: January 06, 2024, 10:20:36 pm »
The two Nomex dielectric loss data are mediocre, similar to polyester/Mylar at a few percent.
Note that the data are at sub-RF frequencies.
Polypropylene should be about 0.1%.
Depends on how good a capacitor you want, which usually depends on the dielectric.
Offline MathWizard
Re: cap dialectric
« Reply #6 on: January 08, 2024, 08:57:59 am »
What about something like hot glue ? If you glued together some metal sheets. I have an LCR meter and calculator, I need to try some of this. Like making variable caps out of tin can's.
What about if you wind some inductor and coat it in hotglue ? If the coil radius is large enough, wouldn't still be an air core inductor. I need to play around with inductors more, like putting different materials inside them.
Offline TimFox
Re: cap dialectric
« Reply #7 on: January 08, 2024, 06:04:41 pm »
Back in the day, we used “Q dope”, which was polystyrene dissolved in a solvent (acetone?) to exploit the low dielectric loss of polystyrene.
Re: cap dialectric
« Reply #8 on: January 08, 2024, 09:20:24 pm »
would 2 sheets of fr4 copper clad  (1.2mm thickness? glued back to back work as a cap at hf? then?.i have about 150 5"x4" sheets f it,its  to make padding caps for an atu.
Offline TimFox
Re: cap dialectric
« Reply #9 on: January 09, 2024, 02:27:24 am »
With the data sheet values for dielectric constant and loss, and your plate area and dielectric thickness, what capacitance and Q do you calculate?
Re: cap dialectric
« Reply #10 on: January 10, 2024, 11:53:15 am »
i have no datasheet!.just wanted to know if it would work.
Online Andy Chee
Re: cap dialectric
« Reply #11 on: January 10, 2024, 02:34:33 pm »
Put a sheet of Nomex in your microwave oven for 30 seconds.  Make sure you have a cup of water in the microwave alongside your sample Nomex.
If the sample gets warm, it's no good for your RF antenna tuner application.
« Last Edit: January 10, 2024, 03:50:39 pm by Andy Chee »
Offline TimFox
Re: cap dialectric
« Reply #12 on: January 10, 2024, 03:24:13 pm »
I’m sure you can locate dielectric data for FR4 through Google.
How can anyone else answer the question if it would work without a clue about the required capacitance and Q?
