For getting tranformers there may be a better, more local source than Ali- express. They are just a bit heavy for shipping.
A European alternative would be this: https://www.tme.eu/en/details/ts4_30/transformers-with-fastening/indel/ts-4-30/
Just to confirm that this transformer is installed and work nice. Thank you Kleinstein!
I have not tested it yet thoroughly because I plan to replace the electrolytic capacitors and clean it, but so far it look just fine. No obvious problems.
Off topic:
Mechanic switches was worked very poor on this device, often did not lock etc. I have clean it with the contact cleaner and now there is no any problem it switch nice and lock everytime, just clicking sound is somehow strong and sharp, not sure it is normal, there must be some kind of grease there.
Is there some dielectric greasing spray that can be used here to get smooth movement and sound when switching, to grease it?
