Regardless, he's not going to find a mosfet with greater than +/-20V Gate-Source breakdown. For his automotive application, he's going to need that Gate-Source protection Zener, so you can't just connect the gate directly to the driver transistor collector - you must limit the otherwise high energy current spikes with a resistor in between, otherwise the Zener will just shunt all of the spikes straight into the driver transistor. With the needed Gate-Source resistor too, you inevitably end up with a voltage divider driving the Gate.
