I've just seen a YouTube vid (Afrotechmods) using a p-channel MOSFET as a reverse polarity protector.
The theory being that, in the forward mode, the power loss is less than any diode.
I was going to use a Zener as both a reverse polarity protector and an over-voltage protector (when the power is connected the right way).
Is there a way to use a "device" to do the job of the Zener but with the low power dissipation of the MOSFET?
Thanks.
