Author Topic: P-MOSFET reverse polarity protection  (Read 1054 times)
Offline PerranOakTopic starter
« on: September 14, 2018, 11:49:50 am »
I've just seen a YouTube vid (Afrotechmods) using a p-channel MOSFET as a reverse polarity protector.
The theory being that, in the forward mode, the power loss is less than any diode.
I was going to use a Zener as both a reverse polarity protector and an over-voltage protector (when the power is connected the right way).
Is there a way to use a "device" to do the job of the Zener but with the low power dissipation of the MOSFET?
Thanks.
You can release yourself but the only way to go is down!
RJD
Offline cbc02009
Re: P-MOSFET reverse polarity protection
« Reply #1 on: September 14, 2018, 12:05:41 pm »
Thanks.
If you're looking for a MOSFET solution specifically, I've seen MOSFET controllers like the LTC4365 that drive a mosfet (or a pair of them) to protect against over voltage. You set the voltage limits with a resistor divider.
« Reply #2 on: September 14, 2018, 02:16:12 pm »
Cheers.
No, anything will do just with cheap parts and without wasting loads of power.
RJD
