Author Topic: Schwinn 3 mode Bicycle Safety Light question  (Read 899 times)
Offline sambonatorTopic starter
« on: March 14, 2019, 01:31:04 am »
So in my pursuit to learn more about analog circuits, I tore down my Schwinn bike safety light.
It has 1 button that toggles the LED's between on, flashing, and off.
I've identified a 22Ω resistor, 0.95µF capacitor (by measurement), and what looks like a transistor... can anyone tell what that is?
How does that allow me 3 modes of operation with a pushbutton?
Attached at the pictures of the unit.
Thank you!
Offline Zero999
  • 0999
Re: Schwinn 3 mode Bicycle Safety Light question
« Reply #1 on: March 14, 2019, 09:01:57 am »
The capacitor has 105 written next to it, which means 10 00000pF or 1µF. It's probably for supply decoupling, but there's a possibility it's for timing.
The resistor no doubt limits the current through the LED.
The transistor lookalike device is an integrated circuit but without the part number your guess is as good as anyone's.
The following users thanked this post: sambonator
« Reply #2 on: March 14, 2019, 04:57:46 pm »
Thank you Zero999.  Didn't realize 105 was referring to the capacitor value.  Another step forward in reading printed circuit boards! ;D
I'll dig around a bit to see if I can find info on this IC and post if I find it.
Thank you for your analysis!
Offline Kasper
« Reply #3 on: March 14, 2019, 08:18:55 pm »
I am betting the IC is a micro controller (MCU).
Offline AndyC_772
« Reply #4 on: March 14, 2019, 08:45:22 pm »
You might struggle to find exactly what it is. Packages this small don't have room on them to write the full part number, so manufacturers use a cryptic few characters instead.
Add to that the fact that it's quite likely to be an Asian market device that isn't sold in western markets, and may not have a data sheet in English.
Chances are it's something like this, though:
http://ww1.microchip.com/downloads/en/DeviceDoc/Atmel-8127-AVR-8-bit-Microcontroller-ATtiny4-ATtiny5-ATtiny9-ATtiny10_Datasheet-Summary.pdf
Offline Zero999
  • 0999
« Reply #5 on: March 14, 2019, 08:56:59 pm »
Possibly but I don't recall seeing a five pin MCU before. Six pins is the lowest MCUs normally go. I think it's more likely an ASIC.
I'm surprised it's in a surface mount package and not chip on board, which is more common for this sort of thing.
