Industrial controls can have surprisingly long lives, I know of one set of elevator control gear that is still in service and is relay logic built on a slate bed for example, it just works so nobody touches it (Which is probably why it stays working!).
There are still more then a few sets of 1970s phase angle controlled lighting dimmers in active service in theatres up and down the land, and plenty of similar kit in dark corners of older plants that just sit there doing the same thing it did for the last 30 years, long forgotten about in some cases and only touched when something breaks.
The trick to this stuff is build it big (so you don't need forced cooling (moving parts)), and build it simple, stuff that does not have custom programmed microprocessors is generally easy to keep working, don't add features just because you can. Simple linear power supplies, with caps that are not stressed remotely heavily, with good airflow and sane derating help. Electrolytics are not the automatic problem you might expect, we have good models for their behaviour... Old Tants are a bigger issue, as are very heavily doped junctions (Think tunnel diodes).
Of course sometimes you just get unlucky in unforseen ways (Old RIFA class X and Y caps for example, nobody at the time saw that coming).
Then we get to test gear, there is a lot of the old stuff in peoples labs, my 4192A, 8753C and the like are all over 30 years old, and still do what they do rather well, but they were both the price of a nice house when new (And having military tools budgets when setting the BOM target cost helps at the design stage).
Generally you will also find that infrastructure stuff is built to have a very long life, look to railway signalling, power network stuff, things like that.
Regards, Dan.
