If you install the LEDs in parallel, they will divide the current among themselves, and this current is limited by the chip, has a finite value. The LEDs will glow about 2 times less or go out altogether if 1/2 of the current is insufficient to glow, if the voltage falls below the threshold. You can turn on LEDs of the same color in parallel, they are about the same, but LEDs of different colors will not work. Putting resistors, hoping for current equalization makes no sense - they will further aggravate the situation with current losses. The CHIP will increase the voltage, but the current will remain constant.
