Author Topic: Struggling to repair a Tek TDS5052B  (Read 618 times)
Offline magnetchiefTopic starter
« on: February 22, 2022, 06:45:41 pm »
Hi, I have an old Tek TDS scope.
The HDD had previously crashed, I had none of the original software for reinstallation of the drive.
I followed the excellent rebuild blog from Ilya @  xDevs  https://xdevs.com/fix/tds5000b/#result
I replace the HDD and cloned the image as per his blog.
Added more Ram and replaced the processor cooling fan.
After booting up, the scope seemed to work as expected.
I installed the various windows and Tek drivers again as per his blog.
I ran the various diagnostic testes and all passed.
But, I have no waveform displayed on the scope from either channel.
I tried to set a couple of measuring options using a PTS input into channel #1. You can see the measurements of the input signal on the attached photos, but no waveforms are visible.
Am I missing something here? Please forgive my lack of experience, but would really like to get this old scope working again.
Many thanks for any advice offered.
Offline Johnny10
Re: Struggling to repair a Tek TDS5052B
« Reply #1 on: February 22, 2022, 08:43:05 pm »
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
« Reply #2 on: February 22, 2022, 10:06:42 pm »
Many thanks.
I think you are onto something.
I will check it out tomorrow and update.
Thanks again.
« Reply #3 on: February 23, 2022, 02:56:52 pm »
Well that took all of two minutes to correct.
You were spot on, thanks for the lead.
Offline Johnny10
« Reply #4 on: February 23, 2022, 03:04:10 pm »
