To get low output impedance and current sharing, there is a 3 rd, better version of paralleling the OP:
Use on OP like in Version A (so getting the feedback from behind the resistor). Use the second OP as a dedicated slave, with the positive input from the output of the 1 st OP, and than wired like Version B.
This is working very well at low frequencies, but may be limited at high frequencies.
This way the 2 nd OP is only increasing the current, the signal output is only determined by the 1.st one.
With stiff virtual GND like in version A (or better C), the capacitors have very limited effect. So one might use less here. With the not so stiff virtual ground in version B, the capacitor can take over much of AC currents and thus reduce the power consumption.
Instead of making the virtual ground so powerful, I would rethink if so much current is needed and maybe avoid it in the first place.
