I just finished creating my first PCB using the toner transfer method. There are a zillion of web pages on the Internet on how to do that and at first I found the whole process a bit daunting: what if I don't heat the paper enough, what if I leave the PCB in the etchant for too long and so forth.
Turns out that actually it's darn easy to make your own PCBs. If you're a beginner / amateur like me, I highly recommend trying it out. Obviously I wouldn't use this method for creating hundreds of PCBs, but for the one-off it's great.
1. I created my board layout in Eagle:
I forced the pads to be 20mil in size to make soldering easier and used wide 50mil traces (mostly because I didn't know how well narrow traces would transfer to the copper and what happens in the etchant).
2. From the nearest supermarket, I got the
cheapest inkjet photo paper (1.80 € for 20xA6 sheets, 170 g/m
2). I hid every layer in Eagle except bottom, pads and dimension and printed it on the glossy side of the paper. I also cut out a small piece of PCB that was slightly larger than my design; again, I didn't want to go too small as I was afraid if I cut it out too small it would get stuck in the laminator.
3. I bought the cheapest laminator I could find from an office supply store, cut out the printout, placed it in top of the PCB and ran it through the laminator for about 10 times or so, varying the angles a little bit.
I didn't really know how many times I should keep doing that; in the end, I used my gut feeling when the copper was so hot that you couldn't really hold the piece with bare hands... and ran it through the laminator twice or so more for good measure.
4. Although people recommend using hot water for removing the paper, I just filled a small tub with lukewarm water from the tap and dropped the board in. After 10ish minutes I tried to pick it a little bit with my finger; if it doesn't come off easily, let it soak for some more. After the paper had softened enough, it was able to remove most of it and the results were looking rather promising:
I was in no hurry and let it soak some more until I was able to get most of the paper off with just rubbing the board with my thumb. I didn't want to push too hard or use a brush because I was afraid I would damage the toner.
It was looking good in the water, so I dried the board and saw that there was a fair share of paper left on the board (it was just transparent when it was wet):
I tried using a sharp scalpel to remove some of the paper; while I was able to break the larger parts I wasn't really able to remove any and I think it's not worth doing that.
At this point I dropped the board back in the water and decided to take the risk of scrubbing the board with a rough cloth. It worked pefectly and my fears were unbased as I didn't damage the toner on the board at all; in fact, I think I could be a lot more aggressive with cleaning the board without damaging the traces.
There were some minor faults where the toner hadn't transferred well (or I had scrubbed it off -- who knows), so I touched those places up with a fine-point waterproof marker that I usually use for writing on CDs.
5. For etching I bought some sodium hyposulphite (I'm not really sure about the English name, the formula should be Na
2S
2O
2) from the local electronics store. The guide said to mix it 1:5 with ~50C water and the board should be etched in about five minutes.
I think I messed up the ratio and as I didn't have a heater it took me a while to figure out how to keep the solution heated (place the plastic cup into a larger cup of hot water), so it took me about 40 minutes to etch the board. At some point after 10 or so minutes I was wondering if it was working at all as I could see no change on the board; soon enough the solution started to turn blueish and after 20 or so minutes the board was done:
After removing the toner with some acetone:
I think the board turned out pretty darn good. It's interesting to note that the small border line that was transferred somewhat OK was almost completely gone; I guess that is below the lower bound of what's achievable with this kind of home etching.
Next up, finding a drill, transferring a "silkscreen" on the top and soldering the board.
