https://www.electronicwings.com/pic/pic18f4550-timer-capture/*
Frequency Measurement using Input Capture Mode in PIC18F4550
http://www.electronicwings.com*/
#include <stdio.h>
#include <stdlib.h>
#include <p18f4550.h>
#include "osc_config.h"
#include "LCD_8bit_file.h"
#include <string.h>
#define f_timer 2000000
void main()
unsigned long signal_period,data1,data2;
unsigned long frequency_Hz[20];
float Frequency;
TRISCbits.TRISC2=1;
OSCCON=0x72; /* set internal clock to 8MHz */
LCD_Init();
memset(frequency_Hz,0,20);
LCD_String_xy(0,1,"Pulse");
PIE1bits.CCP1IE=1;
PIR1bits.CCP1IF=0;
CCP1CON=0x05; /* Capture mode is selected for detecting Rising edge */
CCPR1=0x00; /*CCPR1 is capture count Register which is cleared initially*/
TMR1IF=0;
T1CON=0x80; /* Enable 16-bit TMR1 Register,No pre-scale,use internal clock,Timer OFF */
TMR1=0; TMR1ON=1; /* Turn-On Timer1 */
while(1)
while(!(PIR1bits.CCP1IF)); /*Wait for Interrupt flag which is generated when edge is detected*/
PIR1bits.CCP1IF=0;
data1 = CCPR1; /*Copy count of 1st edge detected*/
PIR1bits.CCP1IF=0;
data2 = CCPR1; /*Copy count of 2nd edge detected*/
if(data1 < data2)
/*Calculation for Frequency Measurement*/
signal_period = data2 - data1;
Frequency = ((float)f_timer / (float)signal_period); /*Count for 1 cycle*0.5us gives period */
sprintf(frequency_Hz,"%.3f ",Frequency);
LCD_String_xy(2,0,frequency_Hz);
TMR1=0; memset(frequency_Hz,0,20);
this is the code which measure Frequency of the input signal and display it on 16x2 LCD. I want to convert this code from mplab to mikroc .But i mikroc when i declare
TMR1=0; it shows error.How i can overcome this problem??
