Author Topic: Unconnected USB 5V?  (Read 2351 times)
Offline EmilTopic starter
  • Country: no
    • ZeptoBit
Unconnected USB 5V?
« on: January 29, 2015, 12:39:58 pm »
Can USB +5V be left unconnected in a circuit which is not USB powered? Or should it be terminated in some way?
Offline rexxar
    • Forever Tinkering
Re: Unconnected USB 5V?
« Reply #1 on: January 29, 2015, 04:11:23 pm »
I don't think you need to do anything special. I've left the 5V line disconnected before with no ill effects, but I was moving very little, very slow data. Your mileage may vary.
Offline Monkeh
« Reply #2 on: January 29, 2015, 04:23:02 pm »
A USB device is required to expose a capacitance on the VBUS pin of its connector of CRPB. This
capacitance shall be greater than CRPB min for voltages on the VBUS pin from 0V to 5.25V,
regardless of whether the USB device is powered or unpowered.
http://compliance.usb.org/index.asp?UpdateFile=Electrical&Format=Standard#59
http://www.usb.org/developers/docs/usb20_docs/usb_20_121314.zip
« Last Edit: January 29, 2015, 04:24:51 pm by Monkeh »
Offline katzohki
    • My Blog
« Reply #3 on: January 29, 2015, 05:00:54 pm »
So put a 1uF capacitor on 5V line and leave it at that. Good to know!
Offline Monkeh
« Reply #4 on: January 29, 2015, 05:14:19 pm »
Minimum 1uF, acros the entire applicable voltage range (0-5.5V). Be mindful of your tolerances and DC bias.
If you're building something USB I do suggest thoroughly reading the specification.
