To set the current limit, first set the voltage limit, you already know how to do that.
Then put your multimeter in the 10A current range and probes in the appropriate sockets for measuring 10A current.
Short the output of the converter through the multimeter, so you can measure the "short-circuit current".
(Obviously, you ONLY have the multimeter connected here, don't go shorting out a battery connected to the output!)
Adjust the current potentiometer until it is at the limit you desire.
