Author Topic: PCB prototype production company  (Read 2602 times)
Offline VoidsWarrantiesTopic starter
« on: November 24, 2016, 02:58:31 pm »
I am looking for a good and cheap company that I can get pcbs from. I made them with fritzing and they do have their own production service but it it 25$ a board. Fritzing does let you export it
It is 20mm by 170mm
Double sided
Only through hole no smd
Sent from my iPhone using Tapatalk
Offline ataradov
    • Personal site
Re: PCB prototype production company
« Reply #1 on: November 24, 2016, 06:07:06 pm »
Export to Gerber and go to OSHPark or PCBWay.
Alex
Offline Zero999
  • 0999
« Reply #2 on: November 24, 2016, 09:10:20 pm »
Etchable PDF & SGV? Those formats don't sound suitable for PCBs because it won't be obvious which layer is which.
Offline Blastcap
« Reply #3 on: November 25, 2016, 08:55:31 am »
But useful for those who want to etch boards themself.
Offline daveshah
  • Country: at
    • Projects
« Reply #4 on: November 25, 2016, 04:37:34 pm »
Elecrow get a recommendation from me, would be $28.50+shipping total for 10 boards of that size and they should take the exported Gerber files.
The following users thanked this post: alexanderbrevig
Offline CraigHB
« Reply #5 on: November 25, 2016, 05:36:19 pm »
I have yet to find anyone cheaper than Osh Park for one off PCB fabrication.  Though you can do better when numbers are higher, the usual supsects like ITead and Seeed have very good prices with a minimum quantity of ten.  I've used Smart Prototyping before and they have very good prices similarly.  Typically for a hobbyist you would not have need for more than one or two copies so Osh Park is going to be the cheapest option.  If you're in the US the service is about the fastest you'll find.  I have had boards turn around as fast as a week with them, but two weeks is more typical.
The industry standard is Gerber and Excellon plot files.  If you're using software that is not able to produce those, you'll need to migrate to something that can.  There was (is?) a trend for prototyping services to require use of their own in-house CAD software in an effort to lock you into their service.  Typically their CAD programs use a proprietary file format and are not able to produce Gerbers.  The software can be pretty good, Express PCB is one, but it's not a good thing to pigeon hole your designs like that.  It's going to give you trouble at some point.
« Last Edit: November 25, 2016, 06:00:57 pm by CraigHB »
