It looks different when I open it up, the filled planes are gone.
Could it be my Eagle settings?
All looks fine.
The only things I question are those resistor values. The current through the LEDs will be different because the forward voltage of different colours will be different. You also might not want them to be the same brightness, in my experience of colour LEDs, to make white, green needs to be brightest, followed by read, then blue. It's not a big deal, unless you're going to get 1000s built for you, as it's easy to change the resistor values afterwards.
