Author Topic: PCM2900 suspend flag  (Read 530 times)
Offline teusTopic starter
« on: January 11, 2020, 02:55:56 pm »
I'm trying to understand the SSPND flag of the USB DAC PCM2900. Does the suspend go active when the USB data lines are disconnected... or when the DAC is connected to a USB host, but the host isn't expecting the DAC to do any decoding?
My PCM2900 always has 3.1-3.2V on the SSPND when connected by USB to my PC. Nothing else is connected to SSPND. I was hoping SSPND would go down when there's no decoding going on, because I get a click sound every time I start or stop playing sound. Putting the amplifier IC in suspend, with or without a small time delay, would fix this problem.
http://www.ti.com/lit/ds/symlink/pcm2900c.pdf
« Last Edit: January 11, 2020, 02:57:36 pm by teus »
