Author Topic: PE on dual adjustable output supply  (Read 715 times)
Offline queennikki1972Topic starter
  • We all start out as newbie's..be kind
« on: September 19, 2019, 01:40:05 pm »
I know from the past I could use PE on the negative or positive side on a single output supply as an external option but this one is different.
In this example image provided, it shows each side of the center tapped transformer being positive and negative and sharing the center as ground when only using positive 30vdc or negative 30vdc and getting 60vdc across the + and - combined. My question is, where is PE in this scenario? Can you safely connect PE to the GND pin even though its technically the center of the transformer?
Im sure this has been covered but I must have missed it and wanted to provide the drawing to be sure my question was understood.
Nikki
« Last Edit: September 19, 2019, 01:48:32 pm by queennikki1972 »
Siglent SDS 1202X-E - Heathkit IO-4105 - Dr. Meter 0-30v 5a power supply - 862d+ combo unit - Weller WLC100 - Kunkin KL283 DC load. Not much gear yet.
Online ledtester
Re: PE on dual adjustable output supply
« Reply #1 on: September 19, 2019, 01:41:54 pm »
If the power supply is isolated you can connect PE (physical earth) anywhere.
The following users thanked this post: queennikki1972
