Author Topic: Peak detector  (Read 1388 times)
Offline thefatmoop
Peak detector
« on: May 30, 2013, 01:18:28 pm »
Hey everyone,
I'm trying to make a peak detector to detect the maximum amplitude of a 1kHz to 100kHz - possibly up to 500kHz sine wave. I followed the peak detection circuit here http://en.wikipedia.org/wiki/Precision_rectifier
but looks like my 4Mhz op amp http://www.adafruit.com/products/808 can only do peak detection up to about 20Khz or so. I'm using a 1N1418 for the diode.
Video demonstrating limitations
http://youtu.be/MzKXaQ6AHoM
So looks like I need an op amp with more bandwidth. If that's the case, does anyone know of a good/semi cheap 8pin DIP MOS (single rail psu) op amp to do the job?
« Last Edit: May 30, 2013, 01:37:28 pm by thefatmoop »
Offline qno
Re: Peak detector
« Reply #2 on: May 30, 2013, 02:12:48 pm »
Use the improved version from Wikipedia.
It will have higher bandwith and ledd slew rate limits.
Why spend money I don't have on things I don't need to impress people I don't like?
