Author Topic: TSOP4138 false triggering ???  (Read 1116 times)
Offline andybarrett1Topic starter
« on: December 07, 2018, 08:12:19 am »
Hi and thanks for reading
I have interfaced a Vishay TSOP4138 IR receiver with a Microchip PIC 16f648 all is good and works well.
But all I am interested in is the first falling edge on the output of the 4138 when it sees the presence of a 38Khz source.
*** I suspect I am getting false noise and this is triggering my Pic ***
*Circuit is a per datasheet*
Looking at the  datasheet the TSOP4138 does have a pullup (25k) but what I am wondering is if I put a harder pull up (22k maybe) in parallel  then  a 0.1uf cap to ground from the OP pin to the PIC.
Would that act as a hardware  filter.....???
Advice and help welcome thank you again for reading
BR
Andy
« Last Edit: December 07, 2018, 08:15:37 am by andybarrett1 »
Offline Buriedcode
Re: TSOP4138 false triggering ???
« Reply #1 on: December 07, 2018, 09:45:11 am »
These devices are very sensitive to noise on the power supply, as well as EMI.  I recently used a similar device and ended up with 100 ohm resistor with a 47uF cap as a LPF for the Vsupply.  I believe the application circuit in the datasheet also has this filter (but with no part values).   A good start would be a 47ohm resistor with a 10uF cap.
With that said, it will still probably get false triggers on the output, and your software should be able to cope with these.  When a remote is sending a signal the AGC kicks in and reduces the gain, so you won't get false spikes in the middle of a transmission, only when its idle.  Your software should be able to distinguish between a valid signal (NEC, sony, RC-5) and false triggers.
