I am not sure what you are intending to show there, but it is exactly what I said -- the diode conducts and is forward biased for the entire positive half-cycle, and part of the negative half-cycle of the power supply. At a certain point the inductor current drops to zero. At this point, the diode shuts off and prevents reverse conduction. dI/dt is now zero, so the voltage across the inductor instantly drops to zero, and the diode goes instantly from zero bias to carrying the entire reverse bias of the supply. You can clearly demonstrate this by adding taps to monitor the voltage across only the diode and the current and voltage from the source.
For absolute clarity: even when implemented with ideal components, the circuit described never generates an infinite current or current. In fact, it never generates a voltage greater than the peak of the supply voltage. Nor is there an infinite dI/dt -- the only infinite value is the dVdt when the reverse voltage is instantly transfered from the inductor to the diode at cutoff.
Everyone is of course right that there is no such thing as an idea diode. They always have some junction capacitance, turn-on and turn-off time, non-zero forward drop and non-zero reverse leakage. However, this circuit drawn is mostly well behaved without any of that.
