Author Topic: standby power  (Read 1333 times)
Offline tekman11Topic starter
standby power
« on: November 03, 2014, 01:51:22 pm »
Hi wall warts have become smaller over the years so I took one apart.
the input is rectified then feed into some sort of fly back SMPS which provides a output voltage.
Does anyone know of a tutorial which  discuss this subject?
They come in isolated and non isolated flavors, under what situation would a isolated version be used?
Is  input protection on the AC side (MOV or fuses) required?
thanks
Offline Zero999
  • 0999
Re: standby power
« Reply #1 on: November 04, 2014, 09:04:00 pm »
A wall wart should always be isolated, unless the insulation on the equipment and cabling is rated for mains voltages.
Here's a link with more information on switched mode power supplies.
http://www.nxp.com/documents/application_note/APPCHP2.pdf
