-Backstory-
I have a phone charger that was purchased from Maplins (made by intertek) and it gives very painful electric shocks whenever touching the ground connectors on the usb ports, The charger itself has no ground connection on the plug socket. This is the second charger of this model with this issue since i returned the first. I am now also living in a different county to when I had the previous charger so I can probably rule out the buildings power. I did electronic products in school but its been a long time and we never did ac, only dc, so any limited electronics knowledge that I may have had is now fairly rusty.
-Issue-
I want to correctly measure the voltage that is being output on the ground connector. From what i know about dc you measure across the component you want to check. But in this case it is a flying wire and touching it will shock you without any ground connection, so i presume that means it is AC but i could be wrong in assuming that. It also means there is no component to measure across.
So I have tried a couple different methods all giving different results. I have no idea if any of them are correct.
-Images-
This is with the red connected and the black left flying.
This was with red connected to the charger and black grounded on my computers usb port.
This was with red on charger and the black grounded on my computer case.
Thanks, Any help would be appreciated
