From Audioholics forum...
How high can harmonic distortion in an amp be before even an audioholic can notice it?
Given the levels present in modern receivers I'd say it's a lot more than they are capable of producing, assuming you don't overdrive them.
Odds are you'll never hear it unless you overdrive the amp beyond all logic and reason.
If you really want to get anal, check out some of the harmonic distortion figures in speakers. Compared to that of electronics, they'll make the hairs on the back of your neck stand up.
Peter Walker when he did the double blind test with "Golden Ears" who denied that solid state amps sounded ad good as tubes, did something naughty the Golden Eared crowd never forgave him for.
He used his fine Quad II tube amps, the solid sate 303 and the solid state 405. He then told them he had a new experimental amp. Peter had resigned the amp to add 2% THD across the board. The Golden Ears doubled blinded could not distinguish any of the amps.
In Kessler's book the Closest Approach, he is asked why bother to make amps with 0.1% or less THD. He said, because it does not cost any more to make an amp with 0.1% THD, and he could not sell an amp with 2% THD!
