Yes, they don't guarantee proper operation with <20V or >90V total supply voltage between V- and V+.
They do guarantee proper operation with 80V total supply if both inputs are at least 5V away from each rail.
They say nothing about other supply voltages, but in practice the limit will likely be close to 5V from the rails too.
It doesn't really matter if there is some "ground" somewhere between the supplies and where it is, the opamp isn't even connected to it.
