Author Topic: Physics/Mechanics, converting torque to rpm  (Read 948 times)
Offline nForceTopic starter
  • Country: ee
« on: July 26, 2019, 08:18:49 pm »
I would like to know what is "mechanical dynamic equation" in mechanics and engineering to convert from torque to rpm? I know the relation T = J*alpha. But how to include motor characteristics for example slip (induction motor), friction, number of poles,  mutual inductance?
Thanks.
Offline ArthurDent
Re: Physics/Mechanics, converting torque to rpm
« Reply #1 on: July 26, 2019, 09:38:53 pm »
Here is an explanation of the relationship between torque/RPM but your question appears to be multi-part, too general, and not easy to solve in a brief time.  http://www.epi-eng.com/piston_engine_technology/power_and_torque.htm
Offline IanB
« Reply #2 on: July 26, 2019, 09:54:46 pm »
In the physics of linear motion you have:
  (power) = (force) x (speed)
There is a direct equivalent for rotational motion:
  (power) = (torque) x (rotational speed)
In each case you have to use consistent units of measure. So for linear motion you may have:
  power [W] = force [N] x speed [m/s]
For rotational motion:
  power [W] = torque [N m] x rotational speed [rad/s]
These are the mechanical equations.
For electrical equations you will need to consult an electrical engineering text.
Offline ahbushnell
« Reply #3 on: July 26, 2019, 09:57:10 pm »
on the money
