Hi, not sure if this is the right forum. But...
Here's the situation. I play a "game", in which all players have an ir remote.
There's a random countdown. After the countdown ends, the later you press your button, the more you win. But, you must be the first to press it. If someone else presses it before you, you get nothing. If a player presses the button on his remote before the countdown ends, he looses money.
Each remote will only work every 1 second. And the countdown goes quite fast. So, you only get a chance in every game.
I want to get a device that, when it reads my remote's code, blasts ir packets at all the common carrier frequencies for a second or so (jamming all remotes), and then blasts my own remote's code a few times.
I've ordered an ir learner from command fusion, to learn my remote's code. They also have a blaster, but I'm not sure if it can jam the other remotes for so long. ( I think it has a 1000 bit limit).
Can you help me out?
