It's the opposite, to remove the problems derived from RMW using PORT.
11.2.3 LAT Registers
The LATx register associated with an I/O pin eliminates the problems that could occur with
read-modify-write instructions. A read of the LATx register returns the values held in the port
output latches, instead of the values on the I/O pins. A read-modify-write operation on the LAT
register, associated with an I/O port, avoids the possibility of writing the input pin values into the
port latches. A write to the LATx register has the same effect as a write to the PORTx register
For example, you could write "1" to RA1, then read RA1 again, and get 0 because the output didn't had enough time to toggle.
Or if the output was shorted, you would always read 0 no, matter what.
Reading/writing to the LAT register avoid all this.
The output might be shorted or not have toggled yet, but LATA1 will be read "1" just after setting it.
Another example. Imagine you wanted to toggle some outputs really fast in a PIC18.
This might NOT toggle RA1 4 times!
btg PORTA,1,0
btg PORTA,1,0
btg PORTA,1,0
btg PORTA,1,0
But this will for sure (Or at least try, no matter the output load):
btg LATA,1,0
btg LATA,1,0
btg LATA,1,0
btg LATA,1,0
