Author Topic: Car relay and continuity  (Read 3748 times)
Offline allanwTopic starter
    • Electronoblog
« on: July 02, 2010, 01:05:21 am »
I don't understand why terminals 1-3 are connected. From the schematic, I'd think only 2-4 was connected initially. Then when voltage is applied across 3-5, then 1-2 is connected. Am I missing something here?
« Last Edit: July 02, 2010, 01:21:33 am by allanw »
Offline MrPlacid
  • Hobby Hobbyist
Re: Car relay and continuity
« Reply #1 on: July 02, 2010, 01:19:00 am »
I am quite sure you're right. Maybe it's bad datasheet you got there. If you have the same relay, pull it out and check it. If your right, it'll make you feel very good. ;D
    • Electronoblog
« Reply #2 on: July 02, 2010, 01:21:39 am »
Yep, testing my relay, putting 12V across 3-5 makes a click, and switches continuity from 2-4 to 2-1.The trouble is, I'm trying to figure out what's wrong with my car and having this service manual have wrong instructions like this isn't helping...
Offline MrPlacid
  • Hobby Hobbyist
« Reply #3 on: July 02, 2010, 11:45:47 am »
shafri,  I think this is what happen. #3 and #5 form a complete circuit when it is switched on, but it never connect to #1, #2, or #4 inside the relay.
PS: I think allan's relay is working fine and isn't the culprit.
« Last Edit: July 02, 2010, 11:52:00 am by MrPlacid »
    • Electronoblog
« Reply #4 on: July 02, 2010, 01:38:10 pm »
Yeah the documentation is wrong. The relay appears to be fine, so something else is broken (ac/fan stopped working on my car)
    • Electronoblog
« Reply #5 on: July 02, 2010, 02:08:48 pm »
Luckily I do have a full service manual. It says to check this heater relay for fan failure, so I tried that. I believe something must be wrong with the whole a/c power system, because the a/c light won't even turn on. I'll check the fuse next.
