Author Topic: How many nFarads is this X2 capacitor?  (Read 1063 times)
Offline sdancer75Topic starter
  • Country: gr
« on: May 27, 2019, 01:01:52 pm »
How many nFarads is this X2 capacitor ?
Offline wraper
  • Country: lv
  • Country: gr
Re: How many nFarads is this X2 capacitor?
« Reply #2 on: May 27, 2019, 01:51:26 pm »
0.1uF
https://www.tdk-electronics.tdk.com.cn/inf/20/20/db/fc_05/X2_B81130.pdf
I have already downloaded this but I didn't find this information. As far I can understand from the datasheet it depends on the distance between the two leads to compute the right capacity, Am i wrong? What page to look in this datasheet?
Online PA0PBZ
« Reply #3 on: May 27, 2019, 02:04:30 pm »
It's the μ1 on the second line on the top, page 2 of the pdf explains it (but a bit hidden).
Not the most obvious marking I agree...
Offline Audioguru
« Reply #4 on: May 27, 2019, 02:10:47 pm »
Why don't they CLEARLY mark its capacitance LIKE EVERY OTHER CAPACITOR MANUFACTURER??
  • Country: gr
« Reply #5 on: May 27, 2019, 02:24:59 pm »
So the μ1 = 0,1μF on the top of the capacitor or it means 1μF?
The example inside the datasheet as far as I can understand relates the capacitance with the space of the leads? And where the heck it says that 1μ = 0.1μF ?
« Last Edit: May 27, 2019, 02:30:48 pm by sdancer75 »
Offline wraper
  • Country: lv
« Reply #6 on: May 27, 2019, 02:31:57 pm »
u1 is not 1u. u1 = 0.1 uF, 1u = 1uF
They won't describe such simple things you should already know in the datasheet.
« Last Edit: May 27, 2019, 02:35:27 pm by wraper »
The following users thanked this post: sdancer75
  • Country: gr
« Reply #7 on: May 27, 2019, 02:44:46 pm »
Yes, of course, I knew that BUT I thought that it was an internal marking code (I didn't really realize at the begging that this symbol was actually a "u") so my question, in this case, is where should I find a table that this symbol corresponds to a capacitance number!
Now it's all clear. Thank you!
« Last Edit: May 27, 2019, 02:47:41 pm by sdancer75 »
