Author Topic: Pierce Oscillator  (Read 11120 times)
Offline Bienieboo
  • Explore your creativity
Pierce Oscillator
« on: January 11, 2014, 04:50:23 am »
I'm trying to build a basic pierce oscillator on my breadboard.  I just googled the schematic and decided to throw it together but it's not working.
I posted a picture of the setup with shots of the scope  . I clamped the probe at the output of the inverter and clamp the ground down.  I took shots of the scope with ground(flat line) and without ground connection (sinusoidal waveform).
I used the following:
2 - 47 pF capacitors
1 - 1Mohm resistor
1 - 7404 inverter
1- 20Mhz crystal
Power -5 VDC
I'm not getting what I expected and ended up with a 57 peak to peak voltage and 60Hz with ground removed on the probe. And flat line with the ground lead connected from the probe.
I'm a newb at this and just starting learn basics so thanks in advance for the help.
Offline NANDBlog
  • Current job: ATEX certified product design
Re: Pierce Oscillator
« Reply #1 on: January 11, 2014, 05:20:15 am »
You obviously have too much stray inductance and capacitance to make this work.
Breadboarding is for low frequency, low current, 1980 circuits.
Every wire you are using should be less than 1 cm. That includes power supply, and ground wires, from the closest bypassing capacitor, which you have to add.
Also, you need to pull up/down those floating inputs.
You did not include datasheet/type for the crystal. Is it for 47 pF? Please read the friendly datasheet for it.
Also, learn how to set the scope properly. You will not have 57V on that circuit in any case. And how to make screenshots to a flash drive.
Offline c4757p
  • adieu
« Reply #2 on: January 11, 2014, 05:29:33 am »
He does indeed have 57Vp-p (20V RMS). At 60 Hz.
Bienieboo, when you disconnect the ground lead, your circuit becomes effectively an antenna, picking up interference from nearby power lines. That's what you're seeing. It can easily be 57V P-P. The flat line occurs when the probe is connected properly, which is what you should be seeing because that circuit isn't working.
Offline Bienieboo
« Reply #3 on: January 11, 2014, 05:45:58 am »
Thanks for the response.
 I lost you at bypassing capacitor, pull up/down floating inputs.  I couldn't track down a data sheet for the 20Mhz but now that I'm looking at an example what am I looking for particularly? I can see that for my other spare 16Mhz MP-1 M-Tron crystal it has a Shunt Capacitance of 7pF and a Load Capacitance of 18 pF and ESR of 25ohms for the 16Mhz range.
I can make screenshots to flash drive???thanks awesome.
Offline edavid
« Reply #4 on: January 11, 2014, 06:20:50 am »
The biggest problem is that your feedback resistor is too large for TTL.  However, it is true that your layout sucks, and it's hard to get a 20MHz circuit working on a breadboard even with good layout.
Read this page and see where it gets you:
http://www.z80.info/uexosc.htm
Offline NANDBlog
« Reply #5 on: January 11, 2014, 06:38:03 am »
He also has divide by 10 set up on the scope. 5,7V is more believable.
Offline c4757p
  • adieu
« Reply #6 on: January 11, 2014, 02:36:37 pm »
That looks like a 10X probe though, so it's sensible. And I've never seen mains pickup as quiet as 5.7V
Offline Bienieboo
« Reply #7 on: January 11, 2014, 05:06:12 pm »
@edavid
okay so i rewired it so the paths are as short as possible and followed one of the links you showed me and it seems to work.(60 Mhz, 4 volts peak to peak) at least i get some sort of wave not the frequency of the cyrstal but it works which is good enough for me. All that noise when in auto mode or waves in different phases what do you call that?
I used the series resonant circuit diagram.  I noticed if I play around with the capacitor value or remove it completely that it changes the frequency. Cool.. Thanks!.
Anyways thanks for the feed back.
parts used.
1 -  10000 pF
1 - 100 pF
2 - 220ohm resistor
1- 16Mhz crystal m-tron
1- 7404 hex inverter
Offline edavid
« Reply #8 on: January 11, 2014, 05:50:52 pm »
It sounds like your crystal isn't doing anything - try unplugging it and see if anything changes.  Maybe it's broken.
If it's really there in the signal, it's called jitter, but it's more likely that the scope's trigger settings are not right for the signal, so it is triggering erratically.
Offline KF5OBS
    • RF Electronics Blog
« Reply #9 on: January 11, 2014, 06:29:00 pm »
The Breadboard probably screw you up a bit there. I've seen people put a single sided copper clad board under the breadboard and connecting the board's ground to the copper clad. 20 MHz is a lot for a breadboard. Got  crystal of some frequency below 10 MHz around to try? Also, if your crystal is an issue, you can test this with a 'crystal' tester I designed a while back. It's nothing else but a simple pierce oscillator also. You can find the drawing here: http://jaunty-electronics.com/blog/2012/08/simple-oscillator-as-crystal-tester/
I know that that pierce circuit work very well. So you may want to try the values I use in the drawing and vary the elements to compare your circuit with mine.
The circuit uses a BC547. You can use a 2N2222, 2N3904 or similar multi-purpose transistors with no problem. As a matter of fact, the latter are probably a better fit than the BC547.
EDIT: Just now noted that I never made an English labelled circuit drawing. The left side is where the crystal gets connected and the right side is the signal output.
« Last Edit: January 29, 2016, 06:54:33 pm by KF5OBS »
Electronics enthusiasts and master of RF circuit design, also known as the art of Voodoo. My blog: http://jaunty-electronics.com
Offline edavid
« Reply #10 on: January 11, 2014, 06:37:57 pm »
His oscillator is running fine at 60MHz, so the breadboard is not the problem...
Offline KF5OBS
« Reply #11 on: January 11, 2014, 06:51:18 pm »
Yeah right. What? The breadboard is always a problem above maybe 10 - 15 MHz. Something is obviously not working if the crystal frequency is 20 MHz and that darn thing oscillates at 60, right? The crystal is probably working very well, but is being operated in its third overtone.
Offline edavid
« Reply #12 on: January 11, 2014, 07:48:58 pm »
How can an oscillator run in overtone mode with no LC tank?
His crystal is probably bad or not connected, the oscillator is free running...
Offline KF5OBS
« Reply #13 on: January 11, 2014, 08:05:33 pm »
Sure, it just by coincidence oscillates on three times the crystal frequency without much more to it. Or the parasitic capacitance / inductance of the board form a LC tank that's not in favor of his fundamental. Especially on the pierce oscillator just a bit inductance in your collector path turns that  beast into an overtone oscillator. He probably also has a LC tank made up of the junction capacitance of the transistor coupled with the stray inductance of the Breadboard. Not only does it make perfect sense, I've seen that happening more than just a couple times.  Of course what applies for a transistor based pierce also applies for the logic gate base pierce.
« Last Edit: January 11, 2014, 08:09:12 pm by KF5OBS »
Offline edavid
« Reply #14 on: January 11, 2014, 09:23:44 pm »
The crystal frequency is 16MHz, and it is oscillating at 60MHz.  I haven't heard of a 3 3/4 overtone oscillator before.
Offline Zero999
  • 0999
« Reply #15 on: January 11, 2014, 09:52:05 pm »
Yes I suspect it's just free running with the frequency set by the RC time constant and propagation delay of the gates.
Offline Bienieboo
« Reply #16 on: January 11, 2014, 10:02:43 pm »
Yes it appears that it's doing absolutely nothing.
1st photo - crystal removed
2nd photo - 16Mhz Installed
3rd photo - 20 Mhz Installed
When I installed the 20 Mhz seems to reduce the jitter.
Offline Icarus
« Reply #17 on: January 11, 2014, 10:10:04 pm »
@Bienieboo: Are you using X1 probes ?
Offline Bienieboo
« Reply #18 on: January 11, 2014, 10:14:33 pm »
I'm using 300Mhz 10:1 passive probes agilent model: N2863b.
Offline KF5OBS
« Reply #19 on: January 12, 2014, 12:54:39 am »
Well, now you have! Okay, I guess I should have read the whole thread and not just his first post wit the 20 MHz.
@Bienieboo: Have you tried the circuit with the component values as I posted them above?
Offline Bienieboo
« Reply #20 on: January 12, 2014, 02:38:16 pm »
@KF5OBS
I tried the circuit you mentioned and I get a flat line.  When I first probe it, it gave me 56 V pk-pk and 60 Hz. But now it gives me nothing.
Maybe it's wired incorrectly?...I don't see it though.
5 VDC
- R2 100k
- R1 1k
16Mhz Crystal
- C1 47pF
- C2 47000pF
- BC547
Offline c4757p
  • adieu
« Reply #21 on: January 12, 2014, 02:44:17 pm »
1) BC547 has its pinout reversed from the 2N series - you need to flip it around. C - B - E looking at the flat side.
2) Shorten up the white wire and move it closer to the top of the 1k resistor.
3) Put a big capacitor (any size above 100uF or so) and a small capacitor (around 100nF or so) both across the power supply rails right next to the 1k resistor and the white wire. This will serve as a local power tank, isolating the circuit from the inductance of the wires to your power supply.
Offline KF5OBS
« Reply #22 on: January 12, 2014, 05:27:16 pm »
@Bienieboo You have emitter and collector reversed. Just flip the transistor around 180 degrees so that the flat side points where now the rounded side points. If it then still doesn't work, try to make your leads shorter. You have quite some long traces there. But first try flipping the transistor around. And juts to make sure, if it doesn't start oscillating, try a different transistor. That's just to make sure you haven't fried this one while building it up.
Out of curiosity, what's your purpose for the oscillator? Do you have a project you need it for or did you develop an interest in RF and like to experiment some more in that area?
Offline Bienieboo
« Reply #23 on: January 12, 2014, 08:10:20 pm »
@KF50BS
Yea tried to flip it around and nothing happened same result made the circuit a bit more tighter and replaced it with a new transistor too.
Still no result.  I even put a big 22uF cap between the main power and ground rail still nothing.
I actually have no purpose for the oscillator, I was playing around with 555 timer oscillators and that was a lot easier to make, and then I tinkered around with shift registers and the whole idea around SPI's and thought it was cool how the clock signal is the main thing that drove how fast data get's sychronized.
This is really just a learning experience for me, I have no background in circuits at all so whatever peaks my interest.  So at the moment it's clock signals how to control it.  I think I prefer 555 timer oscillators it's much easier to control and wire.  The high speed stuff seems very impratical to prototype on a board so far.
If there's any kind of goal I'd like to be able to program my own chips and understand how to communicate to other components.  The accelerometers and gyroscopes are interesting too but I'm a long way from there.
Offline KF5OBS
« Reply #24 on: January 12, 2014, 10:48:49 pm »
On your picture it almost looks like you have your crystal connected between the emitter and the collector of the transistor. It's supposed to be between the collector and the base of the transistor. So in parallel with the 100k resistor. Is that the problem? If not, try a different crystal (ideally with a lower frequency) and break out a multimeter to check if any connections are acting stupid.
